how about a relay??
Seems to me that you could install a relay that works off the fan power lead to power the AC switch. The fan is always on unless the vent selector is turned to "off". If you use a relay, then when the fan is on, the switch would be powered, but if the fan is off (selector turned to "off"), there would be no power to the AC switch.
The relay would be powered from the fan power lead. The other side of the relay would be placed in the (separate/new?) AC clutch power lead, just prior to the switch. Need to get a relay big enough to handle the AC compressor clutch amp draw.
Does this sound like it would work?? If so, it would solve the condensor freeze up problem and give you AC with any of the vent settings.
Steve
Steve
