Malfunction Indicator Light
Dealer is giving me a hard time
Trucks first birthday
I just saw the light on the dash (small engine block), read the manual which said I needed to see a dealer. :(
I hit the on-off ignition three times and saw this code:
P 1693
P DONE
Next time I started the truck, the malfunction light was out.
Does anyone know what that \code means, and is my truck OK now?
Jim Nunn:eek:
Manual say's.................
A fault has been generated in the companion engine control module.
or
A "companion DTC" was set in both the ECM and PCM.
Basically there should be some other code for a fault. Some faults reset themselves. So maybe that's what happened and this code does not. But I'm just guessing on the latter part.
Garrett
