Got the Mallory pump in tonight, new 3/8 fuel lines from the tank to the OEM fuel filter + Ray's banjo bolts. I installed the Mallory pump back by the fuel tank outlet on the outside of the frame with a Mallory 200 GPH prefilter.
Took the truck out for a spin and could still drag down the fuel pressure to zero (with the UFM set on 5X5), although it takes alot longer now than before with the stock setup. The pump idles at 16-17 PSI and cruises down the highway at around 12 PSI. So I went home and replaced the OEM fuel filter but the results are the same. The good news is that with the fueling box turned off the fuel pressure doesn't drop below 5-6 PSI (the stock lift pump went to zero in just a few seconds).
Guess now I will need to replace that puny little line from the OEM fuel filter to the VP44 with something larger. I have been talking with HVAC prior to installing the pump and he thought the banjo's and the small line between the OEM fuel filter and the VP44 would be a problem.
If anyone has any other ideas please let me know..... Thanks.
Doug
Doug
