Mallory Update
code retrieval for a 1999
Very expensive tires
Well, had fun yesterday on my 80 mile drive home from work, slowest speed was 75mph the first 5 miles or so. after that it was cruising speeds of 80 - 100 all the way with about a 5 mile jaunt at 120 (just to see if I could do it. #ad
). The mallory is working out great, and maintained 10-11 lbs of pressure. Gotta love driving in packs.
Morph.
'99 2500 4x4 QC Std transmission, Purple (usually Mud Red), 10 Disc Changer, 285x75Rx16 BFG Mudders, Amr. Racing Baja Wheels, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper packages. DDIII's, Exhaust, TTPM, Boost Module. Fuel Pressure, EGT adn Boost Guages. Mallory Fuel Pump. AGR Beefed up Steering Box. (fastest farm truck around). And can't forget the hydraulic PigSticker.
2001 Yamaha Raptor, dropped tooth on front sprocket, sand skate II tires on rear, CT Racing Exhaust, Pro Flo Air, Hipo Cam, 11:1 piston, DG Nerf Bars, DuraBlue 2+2 Axle, +2 swingarm, +3 A Arms, Dyna Jet carb kit, and Works tripple rate shocks for the front.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer, 2 horse bumper pull, Round bale Trailer.
1960 Farmal 340 Diesel Tractor.
Morp, I agree. Just got back from Freehold dyno day. Cruising at 70MPH=11 psi's on level ground. Climbing "shallow" grades= 10 psi's for a second or two then the Mallory seems to recover while maintaing the same speed to 11 psi's.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
[This message has been edited by Bigsaint (edited 05-05-2001). ]
