Believer,
Tougher shifts are probably not due to the GL-5 rated lube. I had Red Line GL-4 in my trans for a while. I noticed it was tougher to shift too. I now use Amsoil Series 2000 75W90, its a GL-5 lube. It shifts real smooth. Royal Purple is a very good lube too. I once had an oil analysis done with 5000 miles on Royal Purple 15W-40. The wear metals were LOWER than Amsoil 15W-40 with the same mileage. Tough Oil.
Some lubes just seem to be smoother than others. Red Ram explained it well
Red Ram, Why did Royal Purple stop sponsering Shelly Andersen in NHRA T/F?
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 11-19-2000). ]
