Manual transmission temp: do you need to monitor it?
Valve spring chainge`
new truck
Howdy all,
After seeing several threads about monitoring the temps in the auto trannies, I am very curious as to doing this for a manual. I have the ETH/DEE combo, but don't tow anything, so this is really a moot point for me. I was just really curious to know if anyone ever puts a temp gauge on a manual transmission, or do they ever really get hot enough to worry about them? I've never heard of any type of cooler for manuals, so maybe they don't get hot???
Thanks for the education.
Tom
-- email address removed --
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, DD Stage 3 afterburners & boost module, 4" Jardine exhaust, Amsoil, Psychotty air, black SmittyBilt nerf bars, no silencer ring, Armacoating bed liner, TDR decal, Jack holiday antenna ball
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
Tom, you don't have to worry about the 6-speed overheating unless you developed an oil leak. Those who have mounted a probe in the 6-speed have removed the PTO cover and installed a weld-in fitting for the probe. I would say that if you go to all the trouble to install a temp. gauge, why not just add several probes and use a switch to monitor the various locations (i. e. engine oil, rear-end oil, transmission oil). A gauge gives me a good piece of mind.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
