Engine/Transmission (1994 - 1998) manual transmission
Engine/Transmission (1994 - 1998) 12v valve cover powdered
2nd Gen Non-Engine/Transmission Swap '96 seats for '98+?
94 Trannys
jburelle said:
Thanks for the reply. The 5 sp. that were put in the 94, were they a good reliable transmission?
Yes, they are strong. It is the NV 4500. The only 2 problems are; 1, the 5th gear spins it self off of the Mainshaft. There is a kit to fix this, and I think there was a TSB form Mopar on this. 2, The NV 4500 uses a hard to find lube, called Castrol Syntorq® LT. QUAD 4 x4 has lots of good stuff on their web page for this Gearbox;
http://www.quad4x4.com/NV4500 Parts.htm
Moose
My 99 Dodge fifth gear went out also 2 by4?
I knew this was a problem that Dodge did not want to pay for fixing. My brother In laws Dodge truck 4 by 4 went out also. I went to the dealer about my 5 speed and they said that my truck was a two wheel drive and they did not have that problem. Mine went out at 79,000. Now I only had to pull the tail shaft to fix mine and Dodge would not fix It. This Is a problem on all 5 speed. I now got a new 6 speed dually 2 wheel drive. What problems should I expect?
