Well like good day eh!
Stupid me, I don't have a boost guage, yet !!!
As such all I can really tell you about boost level is that the turbo was barley audiable. Normally it is quite load, as the silencer ring has run away from home.
The EGT I can tell you about, there was no way I could get the egt over 800 ( TST2 Off) no matter how bad I drove, or what load or gear I used. With the new MAP, I can load it up to 1000. With the TST2 on, and with bad MAP, about 900 was top egt temp, were as with a good MAP, a load and a long grade I could run the egt over 1200+ , until I lifted throttle.
under this 1200 deg, load and grade condition, the turbo is quite loud ( wife does not like it)
Same grade with bad MAP , about 900 max, no power and need to drop a gear.
I have a 24' gooseneck ( 9000lbs), west bound ( into the wind)on the marsh ( between NB and NS) with bad MAP ... 100km/hr top speed, with good MAP, truck will pull what ever speed you want.
the cummin's part number for my '01 is 3417030, call Cummins dealer with engine serial number to be certain. They might tell you that it's an order from US factory item only.
Good luck
