ACCELERATOR POSITION SENSOR DESCRIPTION
The accelerator position sensor is located above the VP44 fuel pump. The accelerator position sensor sends a signal to the electronic control module (ECM) when the driver pushes on the accelerator pedal. The accelerator position circuit contains three wires: a +5 VDC supply wire (pin 31), a return ground (pin 32), and a signal wire (pin 25). SENSOR SPECIFICATIONS
OIL PRESSURE SENSOR
Torque (Threaded style) = 40 N•m [30 ft-lb]
Pressure (kPa) Pressure [psi] Voltage (V)
0 0 0. 42 to 0. 58
172. 37 25 1. 42 to 1. 58
344. 74 50 2. 42 to 2. 58
517. 11 75 3. 42 to 3. 58
689. 48 100 4. 42 to 4. 58
ALL TEMPERATURE SENSORS
Torque = 14 N•m [10 ft-lb]
Temperature (ºC) Temperature [ºF] Resistance ()
0 32 30k to 36k
25 77 9k to 11k
50 122 3k to 4k
75 167 1350 to 1500
100 212 600 to 675
BOOST PRESSURE SENSOR
Torque (Threaded style) = 40 N•m [30 in-lb]
Pressure (mmHg) Pressure [inHg] Voltage (V)
0 0 0. 44 to 0. 56
646. 48 25. 45 1. 44 to 1. 56
1292. 88 50. 90 2. 44 to 2. 56
1939. 36 75. 35 3. 44 to 3. 56
2585. 76 101. 80 4. 44 to 4. 56
ACCELERATOR PEDAL (IVS, ISS, & APS)
Idle Validation Circuit Resistance:
For ON and OFF-IDLE states
ISS - MAX Closed Circuit Resistance < 125
ISS - MIN Open Circuit Resistance 100 k
Accelerator Position Sensor coil Resistance:
Between supply and return wires
• 2000 to 3000 ohms
Between supply and signal wires (released pedal)
• 1500 to 3000 ohms
Between supply and signal wires (depressed pedal)
• 200 to 1500 ohms
Note: Released resistance minus depressed resistance must be 1000 ohms.
hope this helps
Oo.
