Map Sensor/check Engine Lite
Rebombing
Warranty Work
I have the check engine light on and one of the trouble codes is the map sensor. Is there a different map sensor for enhanced engines with boost in the 24 psi range? I know dodge doesn't know that most cummins engines have this sensor.
My truck is a 99 3/4 ton with the ecm reprogrammed.
