I just pulled the silencer ring off but I forgot to plug in the Air intake sensor. I started the truck, then turned it off after a second to go plug it in, then I had 2 codes one said Map sensor voltage low, the other said voltage high, I reset the codes and they havent come back, check the intake sensor, maybe a bad connection.
