I noticed that my driver side front marker lamp (orange one on the fender side) was out. I looked at the bulb and it looked completely silver on the inside such that I could not see the filament. So I just replaced it.
Now, when I turn on my lights... this particular marker lamp is VERY dim compared to the right side lamp. And the left turn signal indicator on the dash cluster is also lit constantly but somewhat dim at the same time. When I click on the left turn signal... both the corner marker lamp and the dash cluster indicator flash brightly as they should. When I stop the turn signal... it goes back to the marker lamp being dim... and the turn indicator lamp being dim at the same time.
Its just when the parking lamps/headlights are on that I have the problem. If I shut the lights out... the problem stops. I pulled the new bulb out and my dash cluster left turn arrow is no longer illuminated. I wasn't sure if this is a short circuit so I didn't want to press the issue by leaving the bulb in.
What the heck? Do I have a bad flasher fuse or ??? I recently re-wrapped all of my engine bay wiring and didn't notice any issues with shorts or bare wires. I went over all of it and carefully inspected it before re-wrapping in new tape.
I have a feeling this could be a miserable search.
