Does anyone have part numbers for this damped driveline?
When I had ny c42 and 44 recall done several weeks ago, the
very knowledgeable GM of the dealership knew nothing about it.
Is this available for all models and wheelbases? My '03 reg cab
has a slight deceleration whine, which I corrected somewhat by
establishing the proper preload on the pinion bearings. It was
zero. A friend has the typical 65-70 mph whine under load, which
we reduced somewhat by decreasing pinion depth . 002 by sanding the face of the pinion bearing, as the proper AAM shims
are impossible to come by. Both gear sets have perfect contact
patterns. I feel that the damped driveline, if available, may be
the answer. By the way, the 1150 axle is way overbuilt for a
pickup truck, and very easy to work on with a few Miller special
tools.
