I have an 06 3500 DRW and the master cylinder has started leaking on the inside of the cab. I believe this to be the boost portion of the system because the brake reservoir level is not dropping. Is there a way to fix it or do I need to replace it? Also are there other years with the same mastercylinder taht I could use?
Thanks
Thanks
