Max Boost
Texas, some folks are using a short turnbuckle and a stiff spring to clamp down the wastegate. The turnbuckle is tightened down to put tension on the spring until the wastegate opens at the desired max boost. This method leaves the boost elbow stock, and just adds more closing pressure to the wastegate arm, requiring higher boost to overcome the extra tension.
If your 'friend' is running only the EZ without any other fuel enhancements, then the boost will self regulate at around 30-32 psi. [at least mine did] If larger injectors are installed then the boost will be higher.
Hope this helps your 'friend'
Greg L
