Well i guess I'll ask this question. The injectors i used were the 40 to 42 h. p. marine injector. Truck pulls 21 psi of boost almost immediately from a stop and a max of 950 egt unloaded. The max boost i assume is governed by waste gate?High rpm screw is 3 turns from stock. Only tweak on pump is 1/2 to 3/4 a turn on fuel screw. I thought i read somewhere that the Banks waste gate was preset at 21. 5 psi. Truck pulls strong and at 21 or so psi from a stop to 90mph. Smoke is slight except at intermittent engine temp then its noticeable at idle. Pump timing has been advanced. Any thoughts?
