Max EGT & Trans Slip?
Code P0336 Crankshaft sensor performance.
Banks torque converter
I recently installed the Bank six gun bundle. Exhuast, intake, and six gun tuner with PDA. I have a few questions:
What should the max EGT be? what don't i want to go over? for warning setting.
On the trans slip indicator, what is the most you want to see?
what do you guys have your max trans and engine temp setting set to?
thanks
I have my PDA tuned differently for each level... . Levels 2-4 i have the limit set at 1300 level 5 and 6 its set at 1400 and on the SL setting i have it maxed out at 1600 since I use that setting to race around. I am not sure about the trans slip indicator, but if you are planning on running around any higher than 5 and racing it around I would recommend a VB and TC upgrade. I shot my transmission with just the sixgun and now have a built HTS and could not be happier. My max trans temp is 220 i think and i set the engine temp to 230 however even flogging my truck I have never seen over 205 engine temps...
