MaxBrake controller set-up with GM plumbing
1993 Dodge w350 extended cab with flatbed
Prodigy P2 Brake controller
I have a complete MaxBrake set-up with the GM plumbing tee. Bought it a few years ago and installed into my '06 Duramax. Plugged my trailer in and the control box did not work with the trailer connected. Sent it back to MaxBrake and they repaired it. In the mean time I had bought a P3 as I needed to tow that weekend. Received the MaxBrake back, plugged it in to confirm it worked, and then put it on the shelf. Fact is, I don't tow much, and the P3 worked fine for my boat. Uninstalled the pressure sensor this summer and have everything on the shelf, needing a new home. Make an offer. Thanks.
I would be interested in your setup , so this is with the hydraulic sensor correct?
Yes, it is the complete system including the hydraulic pressure sensor. If installing in a Dodge, you *might* need a different Tee fitting, not sure. This one fits an '06 GM brake system.
Ok so no matter as my setup will be custom anyway . How did this perform for you ? I plan to use this on a custom RV setup with a hydrastar and disc brakes...
