Grizzly
I was concerned about the vibration of the relatively heavy transducer assembly at the end of the 8 inch long supplied brake line causing it to work harden the steel with the possibility of an eventual fracture. Then there is the “problem” of kinking the line when trying to bend it, replacing it with a flexible brake hose just made sense to me, probably over kill though. For me it was just the $ cost vs. potential benefit.
The bracket is just a small piece of 1/8th thick aluminum screwed to the fire wall pinch weld and then a small “U” bolt holding the transducer.
I also forgot to mention that I purchased the Max Brake and a tail gate assist device from- Plug It Right
May you have fair winds and following seas.
I will have to change my signature now!
