Maximum Transmission Temps
Valve Adjustment Question
EGT wire routing
I was wondering what the opinion is on what the maximum temperature should be. I installed a sender in the trans pan just before my last RV trip. It peaked 200 degrees on a hot day pulling a long grade, the engine temp was also at 200. I guess having the sender in the out line will give the best reading, what should I expect there and is there a "trick" way to install the sender there? Thanks for everyones help.
98 12V Dually, Auto, 3. 54, Banks Stinger Plus, Sun Coast TC. BD valve body
Roger, with a dipstick sensor, I usually run
140 on the hwy with 70+ outside temps. Around town it can climb to 180. I hit 220 once climbing a steep grade in Nova Scotia exceeding my max gvwr.
Once you know what your normal ranges are, I don't think it matters where the sender is located. RonL
98 Dodge 3500 QC SLT 4x4, 12V, Auto 3. 54, LSD, Camper pkg, Running Brds, Tow hooks, Tonneau cover, Cobra / K40, Westach Boost / EGT / transmission Temp gauges, Valley class V, Hadley Dual Air Horns, Mopar Bedliner, RS 9000's, Air Lift system, yada, yada, yada.....
99 Lance 1110 Truck Camper
Roger,
200F in the pan, pulling a heavy load, is not bad at all. I start getting a little concerned when it hits 230-240F for extended periods of time.
'99 3500 QC 4x2, Auto, white/agate, 4. 10 LSD, camping & towing pkg. , Mag-Hytec rear cover & trans. pan, Auto Meter gages, Mopar bed liner & mud flaps, Prime-Loc fuel filter relocation kit, Tekonsha Sentinel brake controller, Rancho step rails
'97 Pace American 28' "Aerosport" tag race car trailer
