So this maybe a dumb as #$@* question but lets discuss it shall we? Again this is merely a topic of discussion.
As anyone ever thought of fabing a Dual steering stabilizer from a 4x4 on a 2wd?
I have been thinking about it and looking at my 2wd IFS and I think that I could take the center bracket and maybe weld or bolt it to the lower cross member under the engine. and then attach the shocks to it and the other ends (tie rod brackets) to the Tie rods on either side of the truck.
My question is do you think this would limit side to side steering or put to much extra strain on the rack and pinion system?
I am asking because short of the rack and pinion and steering pump and steering column everything on the front end is new as off 3 months ago and the steering is just sloppy. Every bump or pot hole moves the steering wheel even just a little, driving in the rain and hitting a puddle jerks the wheel to the side depending on the side of the puddle. usually passenger side. I am trying to think of a way to stiffen the front end without buying a new truck, (decided to keep this one since almost paid off) or doing a full swap to a 4x4 front axle since i can find them or even the more troublesome task of swapping everything into a 2015+ 2wd frame.
