I am a pretty decent home wrencher, but this one has me stumped.
My car (2001 VW with 1. 8l turbo engine) has developed an issue over the last two summers.
When the weather gets warmer the car will have a hard time starting. As the temperatures increase, the crank time will also increase. It is only durning a cold-start, once the engine is warmed up it starts normally. In cool to cold weather it fires right up.
I have software on my computer that allows me full dealer diagnostics from my lap-top. Real time readings of the coolant and ambient air temps look normal, i. e. before starting they are the same, and the coolant goes up from there. Fuel pressure after the pump primes is good, and doesn't bleed off for a while. Allowing the pump to prime before cranking doesn't change anything. Once it does fire, the first second or two are a little rough and puts out some black smoke. Car runs great all other times.
So, if anyone has any input, I'd appreciate it and am willing to try just about anything.
