Picked up my truck last night from the dealer, Dominion Dodge, in Salem, VA. They performed the proceedure that folks have been mentioning here about replacing the recirculation door and removing the screen that is supposed to direct more air to the rear vents. I must say, if you have the low air flow to the front vents, go ahead and complain to the dealer so that they will perform this procedure. My receipt contained the numbers CSR# 39 and a number of 24652300 which may have been a part number. It really makes such a difference that when I was coming home last night from the dealer I was looking to slow the fan down (I thought I had it on the third setting), (86 degrees with 75% humidity) because I was actually getting cold, but it was already on the lowest speed!!! What a marked improvement!!!!
Now, when you turn the fan on the highest setting, you can tell the vents are putting out the most amount of air they can for their size. The velocity of the air is fantastic!!! I have 38 degree air coming out of the center vents with the fan on high and recirculate, so it should cool it down quite a bit better now!!!!
This dealer has done a lot of these repairs, and their diesel guy is certainly well trained and experienced because there are no rattles, and the dash looks like it did before the work was started. You can't tell anything has been done! My hat's off to him. Great job!
If anyone has any questions about this, feel free to PM me. I can only say that I highly recommend this repair from my experience with this problem. Everyone in this particular thread that recommended it apparently has experienced the same thing. This is a load off my mind because it will help keep the wife comfortable, and ultimately, if she's cool and happy, I will be happy. Because, everyone knows... "if momma ain't happy, then nobody's happy... "
Thanks for listenin' to my 2 cents worth...
