Methanol-Water injection
A diff. TST x EZ ??
web address
JMSuplanski said:
How are the Snow Performance Boast cooler Stage- 3d systems + 110 HP 769. 00 plus install labor?
I am considering the system myself. The only concern I have heard is a corrosion issue.
Tim W.
Can't say I've had a corrosion issue in the last 3 years running with the Snow system, but I do let it dry out after a run before I shut it off.
Jim
I did hear from one person that when your RPMs are low, the system is still adding water to the motor and could put the fire out, or make the motor run poorly, is their any facts in that statement. If you have been running it for three years you would know! Thanks for the info Grumpy John
John, I turn my system on with a hobbs switch but the new controllers are allot better. I turn my first pump on at 30 psi and the second on at 40 with a max boost of 50. There is no reason to have it full on below say 25.
Jim
