Michelin 265/70.17's
Just a fyi
06 start/run problem
Will these fit ok on the stock third gen dually rim? and will they rub together in a dually configuration without using spacers?. Im sure they would be ok when the truck is empty,what about max GVWR?
I was holding out hope that Michelin would make the 230/80. 17 in BSW as to be able to rotate all six. The 265's look good with roughly the same O/D.
Mac:cool:
CK
The tires in question are the LTX M/S. Are you running then now?. If so can you post some pics so I can see how they look, mainly the duals. I believe the fronts are wont be a problem.
Kind of irritates me that Michelin makes the 235 80 16's in BSW and not the 17's#@$%!
Mac:cool:
