The Basics
1. Arrive 10-15 minutes early to fill out the release and receive training
2. There are 10 People on the court at one time, 5 on the red team, 5 on the yellow
3. There are four 13 minute games in an hour, leaving two minutes to change between games
Other Game Options
1. Three 18 minute games in an hour
2. Five 10 minute games in an hour
3. 30 second team possession Clock
4. Net Only - 2 points for the net, 3 point for &fraq12; court or longer shots
5. 5 second key clock
Driving
1. Put your foot on the gas pedal
2. With the stick pulled toward you, you should be going forward
3. To go backward make one full circle with the stick (360 Degrees) Either direction
4. To turn left, move the stick to around your right knee
5. To turn right, move the stick toward your left knee
6. To stop, move the stick away from you and take your foot off the gas
Scoring
1. The Red Team Shoots at the red backboard, and the yellow team shoots at the yellow backboard
2. 2 points for hitting the backboard, 4 points for hitting the net
3. Shots that bounce of the ceiling are no good
4. The backboard is only the Front, not the top, bottom, back, or sides
Penalties
RUNNING ON THE COURT - EJECTION
Walk on and off the Court if you run the Referee will eject you from that game
SCOOP FOUL - 2 POINTS
Do not beat on each other, the carts, or the ball out of the other guys scoop
Throwing your Scoop also falls under this
HAND PENALTY - 2 POINTS
Only touch the ball with your hands when it's inside your cart or to loosen it in your scoop
DELAY OF GAME - 1 to 2 POINTS
Once your team scores leave the ball alone and let the other team pick it up
GOAL TENDING - 2 POINTS
You must keep one cheek in contact with the seat at all times
PUSHING OFF/HOLDING - 4 POINTS
Don't push off the other carts, the floor, or the walls
Grabbing and holding other carts count as the same
PINNING - 2 POINTS
You can only pin someone without the ball against the wall for 5 seconds
You can pin anybody in the middle of the court for as long as you want
RAMMING - 4 POINTS
Collisions with excessive speed, especially from behind or when their picking up the ball
Try to avoid launching them out the other side of the cart
CRUSHING THE SCOOP - 6 POINTS
If you allow you scoop to get crushed between cars or the wall it will cost your team six points.
SEATBELT VIOLATION - 4 POINTS
Keep your seatbelt on at all time
ASSAULT - 2 to 4 POINTS
Striking an opponent about the head or face
With the ball counts too
HARASSMENT - 2 to 4 POINTS
Verbal, Mental, or physical abuse of your referee
Refs have feelings too
GETTING OUT OF YOUR CART - 8 POINTS / EJECTION
Stay in your cart
BAD ACTING - 2 POINTS
Nothing deserves penalty points more than bad acting
