Here is why:
Well I ripped the center out of my clutch 350+ miles from home but only 5 blocks from my cousin's house in Losangeles but it did hold on long enough to pass the Yuppy in the SUV that was trying to out run me. I have a GM dirve line, ( 4 speed grany gear SM420 and Ranger overdrive). I bought the clutch South Bend Clutch reccomended but they said this might happen. Guess I might have to put a cam plate back in my pump!! I'm going to be able to do the job here in my cousin's drivway. Im wondering If I should get the same style clutch I have now with the big springs in the center or get a solid disk with no springs. I don't really know how important those springs in the center are. The clutch never did slip on me. Anybody know of a good clutch supplier in Losangeles.
I'm thinking about a cam plate that will limit max torque but will give me more fuel on the upper end. What I really want is a flat tourqe curve not peaked like it is now. My drive line aparently is going to give me trouble with 800 to 1000 lbft or whatever I have now. If I could limit it to about 600-650 lb. ft. but keep that all the way up to say 3200 rpm I wouldn't loose any HP but the drive line would last longer. I'm thinking of trying to grind the stock cam plate just on the upper end not on the deepest part of the notch.
