Mike Ellis
This afternoon while cleaning the inside of my refrigerator compartment door, I happened to squirt some regular old "409" cleaner on the door channel, which had yellowed and defied all attempts at removing same in the past. To my surprise, immediately an egg-yolk yellow stream started running down the side of the camper - the 409 just immediately dissolved the yellowing and a quick wipe with a rag produced once-again ivory white door trim.
If you have seen this info a million times, please disregard. If not, give the 409 a try.
On the down side, my Dometic 3-way fridge has apparently given up the controller board ghost and no longer recognizes presence of 120 VAC at the board. I checked it all out with a multimeter, everything appears to be in order and 120 VAC is making it to the board but is not switched over to the AC heater element. In auto mode with no AC competence it switches to gas, the gas ignites fine and the thermocouple puts out correct voltage but the controller soon shuts down the gas valve and puts up the infamous "check light". Seems to work OK in DC mode though.
If I can't find any better info, guess I will try a Dinosaur board. In the meantime, at least my door is white again...
