Great post, OC!!
This is the kind of thing that makes me renew my membership every year. You present a solid case.
I have satisfied myself that lower rpm SHOULD lead to improved fuel economy, even on a diesel. How did I do this? Well, pretty unscientific, but I would rev up to 2K rpm in 4th and hold it there. Without moving the accelerator, I would shift into 5th. Guess, what? It went faster. If my theory were correct, it should have maintained the same speed, just at lower rpm.
This tells me that the level of fueling required to sustain 2K rpm (probably even in neutral) produces more power than you need to maintain speed. Since you are producing more power than you need, you are wasting fuel to cruise at higher rpm in lower gear.
FWIW, I have a July-build 2002 (very late) ETH/DEE 4x4. I am pretty sure I don't have the axle disconnect. With only 13K miles on it (the last 4K with all synthetics) I can clear 20 mpg pretty easily. I seem to get 16 mpg around town (+/- . 5) no matter what I do. In addition to the mods in my sig, I have also installed the Fitch Fuel Catalyst, which I am doing a longer-term test on before I post. It has thus far SEEMED to have given me about 1 or 2 mpg more, and reduced smoke to boot. Like I said, I can still get almost 16 in town, even driving like Mario Andretti with the DD2s making lots of boost. I will post in depth on the FFC once I hit 30K-50K miles or so.
[/B][/QUOTE]
I'm not that familiar with engine operation but I think that may be a moot point bc AFAIK there's essentially no fuel delivery occurring in the gasser going downhill so fuel mileage is basically infinity. Assumes accelerator isn't depressed & therefore engine braking is occurring (it was long interstate downhill coming out of west WY).
This is something that I DO want to disagree with. Gassers DO burn fuel going downhill. A gas engine needs the a/f ratio to stay between 12. 7:1 and 14:1 or so. A gasser will use LESS fuel going downhill in spite of the near-constant a/f ratio, because it is ingesting less air mass. Because it's a throttled engine, the mix of air and fuel it sucks in varies greatly in density depending on the throttle position.
So the diesel burns less fuel downhill than it would uphill because it cuts the fuel rate back while air flow remains pretty much the same. A gasser cuts the AIR flow back downhill while the air/fuel ratio remains pretty much the same. The end result is similar behavior for exactly opposite reasons.
But there IS a difference. I don't know if ALL diesels operate this way, but on OUR diesels, there is no fuel being injected when your foot is off the pedal and engine RPM is above idle. It's almost like shutting down the engine. Fuel injection is restored so smoothly when you get back on the pedal that it's hard to detect-- but you can tell it's happening.
Under hard engine braking in a gasser, air is FORCED past the throttle blades. This is because the vaccuum that the engine can pull is limited. Once the air is forced past, the fuel is injected in a ratio proportionate to air volume. The gasser can't run infinitely lean-- EGT will skyrocket, detonation and preignition will set in, and exhaust valves get burned.
So, yes a diesel will burn less fuel than a gasser going downhill. At least, OUR trucks will!
It is interesting that cylinder deactivation systems are finally starting to catch on for gas engines. Computerized engine management systems allow the engine to shut down the spark and fuel to individual cylinders in a way that doesn't make the engine run roughly. Once these are on the market, THEN a gasser will be able to go downhill and use no fuel to do it!
HOHN
