Ski Bum, some Rams can run the 295s without tire interference with the sheet metal, others can't. I prefer the 285s over the 295s for several reasons:
1) a 285 spare can fit in the OE spare tire location between the frame rails (a 295 CAN'T)
2) the 285 will out handle and corner a 295 (shorter sidewall)
3) often times there isn't enough tire clearance with the 295s in off-road driving situations
4) better deals can be had on 285s
and finally, 5) I feel the threshold tire size with an auto. equipped 24v Ram with the 3. 54:1 axle ratio is the 285. I feel the 295s seem to make the power soggy enough to warrant the 4. 10s. -DISCLAIMER- These are my opinions ONLY. I have driven both sizes and these are my observations and opinions. I will however add, I like the looks of the 295s better, and with the manual transmission, would probably go with the 295s. That's my story and I'm stickin' to it!
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X spray in liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
