Details here: TDR Privileges
BWillson: I see you have a '97 so yes you can just change the speedo driven gear. In '98 they went electronic and started taking the speed from the ABS sensor in the rear differential rather then the transfer case.
Blakers: How on earth do you get 70 mph out of 1760 rpms? I run the same tire size as you and I get 71 or 72 at 2k. I also have 3. 54 gears and a speedometer correction box.
