12 is in the range with an auto, but it is a little low.
There's a few things you could do to improve it probably...
Advance the timing a little. Go from 1. 25 to 1. 4 or better.
Change torque converters. In some cases, it helps, others swear it doesn't.
Open up your exhaust - change that abomination that goes over the axle with a free flowing pipe, perhaps go with a free flowing muffler or no muffler.
If you want more power, change injectors without turning up the pump. That will probably improve your efficiency under load a bit. Of course, if you use the power, it won't help at all.
