i am finally getting around to repairing my 2 corner rust spots on my tailgate. last night i wire wheeled and used a dremel tool to knock the majority of the loose, bubbly rust off of the gate. i have some ideas in mind, although i want your ideas, as i am no body mechanic. my main plan was to make this tailgate look like a "2nd gen" gate, you know, with the strip of black molding running along the bottom edge. i was planning on using the crease below the DODGE badge as a straight edge, and using rubber molding or other type of body molding to cover the rust, while giving the gate a "clean" look. should i bother to prime the rust spots, or is this rusting from the inside out? after sanding, and preparing the lower portion of the gate for the molding, does anyone have any ideas as to what kind of glue or cement i should use to attach the molding?
