Same Bomb! Same issues! Loping
SAME EXACT LOPE! Just installed HRVP44 from Industrial and Mach 1. 6's and Edge Comp.
The loping occurs when going to drive from neutral or park with A/T. Worse with horses and big 35' trailer coming off long highway run to a stop light. Bucks, lopes, chugs like it is firing on individual cylinders. If I keep my brake foot planted about 50% of the time the loping subsides. The other half of the time I am forced to throw A/T into neutral and the idle resolves it's issues. Even does this with Edge comp turned off. Usually run Comp on 1-3 anyway.
Touch the throttle and all lope goes away while in drive, but the problem is sometimes you have to stay stopped at a light in traffic.
Must admit the "cam" sound is cool, I could just loose the hard lope. I even went to the dealer for a reflash. I added the newest overflow spring on the I. P. Next was told to add some fuel additives and lubricants and run the **** out of the motor. This would free up the injector spray nozzle or help them with their reseating. 8 tanks of fuel and 3K miles of pulling 75-80mph down to FL along with a few showy smoke runs has yet to resolve issue. Runs like a scalded dog otherwise under throttle.
Is it the injectors or the pump or Comp? Tough call when you add multiple items at one bombing.
Your items are almost the same as mine except for the EZ. Very interesting!
Any help would be greatly appreciated. Headed for the PS 62 turbo next, but need to resolve this first.
Bruce In Northern Virginia
