Mishimoto Aluminum Radiator
Cummins water pump vanes are...
Fuel Filtration Questions
Has anyone installed the Mishimoto Aluminum Radiator in their truck? If so did you notice a big difference in the cooling capability? I have been fighting an overheating issue when pulling for the last year. Radiator has been changed, thermostat changed twice and tested, fan clutch changed out and tested, temp sensor tested, water pump replaced. So I know it is getting hot when pulling hard. So now I am seriously looking at trying to increase the cooling capacity in an attempt to overcome the heating issue. Before I drop that much coin in a radiator I'd like to find out if someone else has any experience with the Mishimoto or any other radiator that might do the trick.
Thanks... .
It says plastic end tanks and it looks like they only go to 2001... ...
Dodge*Ram 5. 9L OEM Replacement Radiator, 1998-2001
Mishimoto has just released an OEM replacement radiator for your 1998-2001 5. 9L Dodge Ram. The Mishimoto OEM Replacement Radiators feature perfectly created plastic tanks with aluminum cores. These radiators are a direct OEM replacement and require no alterations.
Mishimoto guarantees superior performance and quality with an unmatched lifetime warranty on all parts.
Okay, found the others. $1000. 00 advertised price. Sounds very nice!
Dodge*Ram 2500 w/ 5. 9L/6. 7L Cummins Engine Aluminum Performance Radiator, 2003-2010
Mishimoto has developed an aluminum performance radiator for the Dodge Ram 2500 with a 5. 9L or 6. 7L Cummins Engine. The Mishimoto performance aluminum radiator for the Dodge Ram is the ideal upgrade to the stock radiator. Designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions and protect your truck from overheating. Whether you use your Dodge Ram for daily driving or as a powerhouse for hauling and towing, you don't want to overlook the importance of installing an upgraded radiator for your engine. A stock radiator can not handle the heat that comes along with having a great deal of horsepower. The Mishimoto Dodge Ram radiator features a lightweight two-row core made of 100% brazed aluminum and polished end tanks. Every Mishimoto Performance Radiator is a direct OEM fit, making installation effortless with no cutting or modification required.
