Engine/Transmission (1994 - 1998) Missing Data Plate
My cummins had a new timing case when I bought it. It does not have a data plate on it. Is there a way to get a new one or at least the information that it would have on it? Would the local cummins shop be able to help me get it? Thanks!
97 2500 12v 5sp
Call a Cummins shop, and give them the engine ID. I think there is more than one place that has the #, but call them first and let them know your issue. :D
I know the skinny on this one. .
Call a Cummins distributor an give them the chrysler vin#
Once you give them this, they can convert it to the engine serial number, and send you a paper copy of the fields on the data tag.
Unfortuneately they no longer manufacture the data tags, but will send you a generic model that can be engraved.
The other choice might be to find a 2003-2004 and get the part # off the white vinyl adhesive tag on the engine, perhaps they can run one of those to stick on the gear housing.
I purchased a 98, 12v. that had this issue for my brother. . missing data tag (case prior to us buying the truck) the tech was too lazy to swap them over. . the least they could have done was to grind the rivets and return the data plate to the glove box!
The part # 3926850 (superceeds but no longer manu. ). . this is what was on your truck.
Generic blank plate=3027288.
I don't have the number for the rivets handy. . sorry
Hope this helps, if you find out the originals are available pls. let me know. I/my local research specialist have spent hrs on this. .
Andy
thanks, thats what i needed. I just want the info. It would have been nice if they had left the original like you said. I have to go to cummins to get a coolant hose so I will do that today thanks again.
