i hope someone can help
95 -5 speed 173000 miles
i bought this truck used over ebay had it shiped in from tx when it came in i was out of town and my wife picked it up for me.
she check it out on the outside, started it and every thing semed ok singed the bill of lading and the truck was mine.
630am the next moring i got to see my new used truck. ran outside and started it right up. ran good sounded ,good look good, what a good deal i got . . well!!!! when i took it up to 1800 rpm it missed out and white smoke like crazy. now i have 6 cummins trucks and i havent had any thing go wrong with any of them. . so the frist thing i did was change the fuel filter. .
now out of just habbit i alwayls pour the fuel into a jar and look at it. mmmmm... fuel seams to be a little red???? well maybe someone put a little farm fuel in it. i mean it did come from tx. it could have happend..... so we did the test, pour it out on the ground light a shop towel and see if it will burn!!!!! welll... . you bet !!!!!! it was gas, not diesel . 35 gallons of fuel all the way to the top. . so i drained the tank put on a new filter and hope for the best... now i have had gas in one or two of my trucks before but never this much and i didnt know how long this truck was driven like this.
started it up ran it up 1800 rpm same thing missing out and white smoke. .
the next day i called the shipper and thanked him for the full tank of fuel and asked him if they alwased fill up the trucks the sell... well... ... he told me no, the trucking co. does not want more than 1/4 tank in any cars or trucks that they haul. well... ... . my truck driver did call and say he would be 2 days late because his truck broke down and he was going to go home because he was so close to home. mmmmmm... ..... maybe i should check the miles ... ... . called shipper and 300 miles off... ...
well to get to the point if you sign the bill of lading it yours!!!!!!!
now back to the problem, white smoke( so i was told) means starving for fuel or timming. so we check the timming and it was off 3 degrees fast so we set back to 14. 5 that didnt help.....
started checking fuel pressure at the fuel filter... ... 0... ... well we found the problem lift pump!!!!!! so we replace it knowing that we just knew this was it ... . nope stilled had the same problem.
came in and was reading my tdr mag. and low and behold some one else was having the same problem ... ... white smoke at high rpms he said to check the fuel return valve. so i did sure enough it was stuck. replaced it. oh boy here we go !!!!!! nope still had same problem
oh by the way after replacing the lift pump we got 30 lbs of pressure at filter. . both sides.
i could crack the lines and it would miss out like it should ... . but 4 and 5 sound a little week.
pulled injectures today and had a pop off check, and spray pattern done. pattern looks good and pop off at 3300 to 3500 on all six
all lines have been check for leaks, volume checks ok, return ok
all lines tight no leaks all i got left is the pump!!!!!!!!1
if any one has any input please help !!!!!!!!!!!!!!!!!!!!!!!!
