GeoVeo,
Since you stayed up late to answer, I guess I can be late to work to answer
Sounds like you're doing a better job than me of drawing samples; before I knew better I was drawing pouring them off the top of the filter as soon as it comes off the vehicle. Since I started by this method and the goal is to look for trends, I have continued doing it the same way even though others say that this is not optimum. My thinking is that the trend will still be there (just different starting numbers), and on other boards I've seen that in some applications samples are drawn both pre- and post-filter.
Relative to "Universal Averages", my Blackstone report dated at 12,655 miles on oil, with one filter change at 5721, said "25" was the UA for iron. (Mine was 71 at the dump) Based on that, I believe Blackstone's "average" is the average for all oils, with various mileages, that have been submitted for the ISB engine. Otherwise, they should have "bumped" the number higher for your 30k mile oil than for my 13k oil.
The biggest difference is that my vehicle had less than 24k total at that 12,655 oil dump. I probably have more short trips even though my main commute is 50 miles one way; if you drive 100 each trip then that alone would be twice as many cold starts for me.
Bottom line is that I think your numbers are really that good; I hope mine continue to improve as this engine gets broken in, which clearly was still in progress at 24k.
P. S. - The other thing I think this info shows is that those 5k filter changes and make-up oil are real important in maintaining the quality of what is in the crankcase. On another thread, it was pointed out that the ISB engine has a 16 quart sump in all applications except the Dodge, and that was given as the reason for the 15k oil change on all non-Dodge applications. Those of us going beyond 7. 5k should be giving it that fresh shot of new stuff at 5k, just like GeoVeo has been doing!
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
[This message has been edited by HC (edited 02-15-2001). ]
