TJarecke,
Try setting your AFC (while on the bench) to reach full open at 25PSI of air. When you put it back on the truck try placing the AFC about 2/3 forward. This should be a good starting place. Also swap the big washers around in the afc. This will give the afc more travel. There are threads here on TDR about the washer.
If you don't have the AFC spring mod it may be helpful. I use the medium spring.
As for GSK. I would only do a 3K unless you have 60# exhaust/intake valve springs. A 3K GSK will let you rev with full fuel to about 3600 rpm. If you don't plan to rev more than that then I don't think a 4gsk will help.
Hope this helps,
Tom C
Hope this helps,
Tom C
