KBennett said:Hohn, I liked your calculations, made more sense to me.
Could it be that some pumps flow 150gph at a lower pressure like 5 psi?
Maybe at 40 psi they are only capable of flowing 50gph![]()
Most pumps are rated at "X volume @ X psi"... so yes, the FASS might be rated at 150gph @ 0 psi... I don't actually think I have ever seen a true flow rating for their pumps other than 95gph or 150gph... this coming from someone that owns one too.
I also think you start to exceed the maximum flow of the stock lines, and even custom lines) at some point (a 5/16" line will only flow so much volume at a given pressure)... so it wouldn't matter if you have a pump capable of 300gpm @ 5psi if you are pumping through a line that can only sustain 30gph @ 5psi.
I believe the FASS95 uses 3/8" line while the FASS150 uses 1/2" line IIRC... so a 150 might supply the volume, but not at the pressure these new CP3s are wanting.
steved
