pipeguy said:I got the HTT SP66 with the idea of modded CP3 and injectors... .
I even love it with out the injectors and CP3... ! Its my daily driver and I drive a minimum of 300 miles a day...
cclark746 said:do you do any pulling if so does it surge? Twins are quite the investment dont know if my significant other will allow the allocations of 5grand on my old goat :-{} and i know that twins would be the way to go but if i can get a turbo that will keep the egts in check and not surge too bad during pulling i would be happy
Rams-n-Hogs said:My sledpuller has 0 surge issues when I tow. NGM diesel can attest to that.You just have to learn to drive it, again, as the EGT's can run up over 1200*, if you lug it. As long as you keep boost and RPM's up, and watch your gauge, it's fine. I also keep my boxes turned down, or off, when I tow.
RMalone said:Ahh, the trade-offs. A 66 will tow but isn't as ideal as a 62, and the 66 will cool higher temps better than a 62 but not as well as twins. And the twins
tow and cool better than either, but they cost many dollars.
If I had the sequence to do over I would have started with the 62 and then used it in twins. As it is, I went with the 66 and want twins, which adds to the total cost. Both II and HTT want $600-$800 to convert a 66 to a 62.
BRayls said:you sure , paul told me 80 bucks to change to a 62.
