You bring up another interesting point Texas Diesel... just what amount does the FF heat the fuel. Obviously, the fuel is sitting in the canister for a bit. So it is definitely heating the fuel to some extent... but to what?
From a few posts up, it seems that the FF canister is taking heat off the block since it is mounted to it. When the FF canister is removed, it is not nearly as hot. So given this, even if the FF is "only" heating the fuel until, say, the fuel reaches 100*, that doesn't mean that is where the temps stop. The block continues adding heat and the aluminum (as someone said above) of the FF canister acts as a heat sink so it easily pulls more heat from the block into the canister.
So it would be nice to know what is the operating parameters of the FF heater. Does it start running if the fuel is less than 75*? And does it stay on until some preset temp?
But larger than that, our blocks run much hotter than 75* and probably are closer to water temps eventually which can be near 200*. If this kind of temperature is being drawn into the aluminum FF canister, then your mathematical equation is using the wrong numbers... and a cooler on the return line is helpless to do much about it IMO.
We need more data, that's for sure. But I believe based on the data so far, I may be a fool, but I seem to believe a FF-VP cooler will do me the best good. But I haven't installed one yet with fall knockin' on the door and temps dropping. It's something I'll do next spring probably.
Steve
Steve
