For the umteenth time, I've heard the old "heat doesn't REALLY hurt the VP-44 electronics, besides, if heat and control boards WAS an issue, why don't ECM's fail too?"
Number one, Bosch (regardless of what OTHER critics suggest. . ) has seen fit to upgrade the VP control boards, according to some of their reps, because excessive heat was causing premature board failures. Those board mods are now standard upgrades on all reconditiond VP-44 for the last 2 years.
Critics may debate the finer points of that all you like, many of us involved in these extensive tests and expirements are FULLY convinced of the damaging effects of excessive heat on circuit boards and related components.
It's also worth pointing out that solid-state devices HATE radical swings in operating temps - it causes unwelcome expansion/contraction of delicate internal connections that eventually fatigue and either lose contact, or become intermittant.
Number 2, ECMs/PCMs *DO* fail - perhaps not as often as VP-44's, but they DO fail, as has been reported on this board a number of times!
A few samples? SURE!
https://www.turbodieselregister.com/forums/showthread.php?t=129076&highlight=ECM+failed
https://www.turbodieselregister.com/forums/showthread.php?t=129821&highlight=bad+ECM
https://www.turbodieselregister.com/forums/showthread.php?t=86065&highlight=bad+ECM
https://www.turbodieselregister.com/forums/showthread.php?t=85479&highlight=bad+ECM
BUT, comparing ECMs to VP boards is apples/oranges - they are made by different manufacturers to different specifications and tolerances, perform different functions, and are mounted in different locations and exposed to different airflow characteristics.
Number 3, I have made enough temp runs with my remote temp sensor attached to my VP-44 that I have now removed it, and moved it over to the backside of the ECM, between it and the engine block for another series of temperature monitoring...
Any critics wanna go out on a limb, and start with predictions as to actual ECM temperature swings as compared to the VP-44?
:-laf :-laf
