I suspect the use and expense of hood scoops will prove overkill unless you have personal objections of use of the blower setups Bob and I use - besides, the scoops are only functional at road speeds, and really aren't likely to do much good at slow speeds or after the engine is shut down (heat soak), unless they were physically HUGE in size...
There are VAST open areas around and below these Cummins engines that actually permit lots of airflow - results of another test and thread I did verified tests others had done previously - actual, constantly monitored underhood temps at speeds above 30 MPH or so usually are within 10 degrees of ambient outside temps - not much to be gained by hood scoops while the vehicle is in motion!
I just this past week pretty well finalized my own blower installation, moving the large and ugly temporary scoop from below my air dam to in BACK of the air dam, drilled a pair of 3 inch holes in the air dam for air flow, and the final install came out quite well - far better than the monstrosity I have had hanging below my air dam - time and miles will tell if it's as effective
Here's a pic of what I made up, before it was painted - just a smaller size bread pan with a 3 inch diameter air duct molded into it at the proper location and angle that is then connected to my pre-existing ducting:
