Moisture in fuel
New Furd add
What Brand of Diesel Engine?
If you think you may have moisture in a fuel tank,pickup tank or storage tank,there is a product made to check this! What I use is a paste like product, put small amount on a steel rod or stick,slide down into bottom of tank. Pull out and paste will show different color if moisture is present! Any fuel supplier should have this. If any interest, I'll try to get a name. Have had it around for a long time so may be no name on container. jps
I don't remember the name either but we used it on the pipeline to check the amount of water in the bottom of the storage tanks so that we could get accurate product readings for the fuel.
This is the stuff I use in storage tanks, turns purple if there's water. Might be hard to use in a truck fuel tank though. Most fuel suppliers have it cheap, my tanker driver carries it with him and gives it away if I ask.
