Does anyone monitor the fuel pressure on the 12 valves? I am a recent convert from the 24 valve section where watching the fuel pressure over there is a given, but I don't see much about it here. Is it worth it?
I wanted to put the gauge post filter so it would also watch for retriction. The 97 and my 99 take the same filter so I thought it would be easy and use the same test port on top of the cannister. Whoops! Same cannister, but no test ports? Where are you tieing the gauge in? If I do this, I'll use the westach fp gauge as it matches the combo and transmission temp.
Thanks,
-Vic
Thanks,
-Vic
