Moog 7226S Front Springs
water temp
Wanted: old VE & injectors
Has anyone tried getting these springs from Moog lately? I went to my local auto parts and they called the warehouse. Turns out it is now a factory item. That was three weeks ago. Should it really be taking this long or are they just dragging their rear end?
All I want to do is level that sagging front end out a little! :(
As an aside, at the first parts house I went into (it was a NAPA store) when I asked if they carried Moog Chassis parts, he told me he had never heard of them. I said thank you very much :rolleyes: and went somewhere else.
Carl
CDegner, The Moog Spring repacement (coil) to correct the sag in 89-93 D-250's is PT. # 5716. It gives one a 2" raise. I used the Moog # on my "93" D-250. Changed both at this time and it straightened it out. There is also a Dodge TSB 02-06-90A on this problem.
Chuck Goode
CPG-
did the new springs raise you up enough to fit a lower profile 19. 5 tire under there? I'd like to put some on, and could probably get a deal on them here, but if they wont fit... ... . Guess I could do a 4x4 conversion; they'd fit then.
Daniel
