My 05 did not come with the oem fog lights so I just picked up a Mopar accessory add on fog light kit for $175. Has anyone ever insatlled this kit? There is a lot to it. Apparently the 05 doesn't come with any of the wiring for fogs at all. Have to mount relay and fuse and drill hole in dash for a switch and splice into the lowbeam wire and run an entire harness for the system.
I was thinking of splicing into the park light instead of the low beam so there was the capability to have them on with low and high beams. And I was also going to put the higher lumin bulbs in that Genos has also. and add a bright box.
My 02 didn't come with fogs either but all the wiring was there to just add the lights and plug them in and add the fog style headlight switch.
