I am just about finished with the tow mirror conversion. My truck had the electric/heated mirrors so all the wiring was there. All I did was install the 3rd gen electric/heated tow mirror to the 2nd gen tow mirror base and mount them on the truck. Way cool. They fit right on... almost. I'll explain but first some details of the installation.
After separating the first mirror from its base by removing the spider like retaining washer and having my finger wacked, I learned the following:
I managed to drop two of the nuts holding the old mirror into the passenger door. I hope they don't rattle.
I spliced about a foot of wire to the end of the wires on the new mirrors and reused the original 2nd gen plugs.
Everything works except the end of he mirror control switch hits the top nut & stud of the drivers door mirror. This prevents the door panel from setting flat in its original position. Any one have a work around for this?
Thanks in advance.
PK
a. After loosening the second leg of the spider retaining washer put a towel or heavy cloth over the opening.
b. When the third leg of the spider retaining washer is loosened the washer will produce a satisfying thud as it is restrained by the towel.
c. To ease reassembly I used a coupling and a arbor press to press the spider retaining washer back into position. Very simple and safe.
Thanks in advance.
PK
