D
Deleted member 995608
Guest
Trying to button up ball joint set #5
Since my warranty ran out, I've been using Napa NCP ball joints. The current set lasted 1 year and 6 months :{.
I tried Moog this time however I'm having trouble with the Moog uppers #K7460. The lower joints pressed in as usual. The uppers literally fall into place without the need of a press. I know this fitment isn't correct and completely unsafe. I tried the other upper and it too falls into place; not good. I guess there is a possibility that the Moog joints I received are boxed improperly but what are the chances of getting 2 wrong parts in 2 boxes??
The only noticeable difference between the Moog and NCP's is the lack of knurling on the Moog body. While poking around Dynatrac's website, I noticed they make an additional special ball joint with knurling. Supposedly, the knurled joint is to make of the difference for those of us who have been using non OEM knurled joints previously. It sounds to me like knurled ball joints are in fact opening up the yokes holes in the housing causing damage.
Here's the tech bulletin from Dynatrac: http://www.dynatrac.com/products/freespin-dodge/images/DynatracServiceBulletin.pdf
Anyone else have some input on this? My truck is down and out for the weekend but I need it up and running by Tuesday; time to haul my kids critters to the fair!
